Auteur Topic: weldra...  (gelezen 4282 keer)
Offline Kirsten
  • yes, i'm a Pentaxian! ♥♥
Re:weldra...
« Reactie #30 Gepost op: 7 februari 2011, 09:53:19 »
Wat is de prijs?
39€ inclusief verzending?
Net nog gevonden op een Canon forum:
Not going to write a full review, but I'll post my thoughts about the V5 vs RF-602. Just from playing with them, they seem to be more reliable than the RF-602s.
V5:
-They work with my 5D at max sync speed (1/200). With the RF-602s I could only get clean images at 1/160 or slower.
-Transceiver design, more flexibility and overlap in terms of having backup gear.
-More channels.
-MUCH easier to switch channels, maybe too easy.
-Button/switch layout is better. With the RF-602s you can't really turn the receiver on/off while it's attached to a 580EX II hot shoe. With the V5s you can get to pretty much everything with it attached.
-Use of AAA batteries, so no weird/different sizes between units to deal with.
-Battery door design is really nice.
-They screw down onto your camera's hot shoe. The RF-602 transmitter was too loose for my taste.
-I like how they have a switch to turn them on. The transmitter on the RF-602 just has a button you press to wake it up. This is a poor design IMO, it seems like it has caused the system not to trigger my flash a few times because the transmitter wasn't awake, but I could be wrong. I just ike to know that it's actually on and ready to go. Also, the button isn't recessed and seems like it would be easy for something to press against it in my bag and drain the battery. Just my $0.02.
RF-602:
-A good bit smaller than the V5s.
-Pretty much guaranteed not to change channels on accident. Think I may have done this with the V5s once, the dial seems a a little too loose.
Re:weldra...
Offline kraayke
    • Tractor pulling
Re:weldra...
« Reactie #29 Gepost op: 6 februari 2011, 14:59:52 »
Iemand interesse in een setje Cactus V4? perfect werkend, slechts enkele maanden oud en paar keer gebruikt.  :)
Wat is de prijs?
Offline Kirsten
Re:weldra...
« Reactie #28 Gepost op: 6 februari 2011, 02:25:04 »
Leuke link Andre, waarvoor dank!
Re:weldra...
« Reactie #27 Gepost op: 25 januari 2011, 19:26:13 »
en alweer uitverkocht :D
As many of you are aware, the Cactus Wireless Flash Transceiver V5 (V5) was released yesterday, and after less than 15 hours, the V5 Duo was all sold out while a limited number of V5 Single is still available.
We are extremely excited about the high demand for V5. However, given that each V5 unit is inspected one-by-one to ensure quality and reliability, our supply level is insufficient to meet this unexpected high demand. In light of this, we are making efforts to increase our production supply, and hope to achieve this within the shortest timeframe possible.
For the time being, we will make a limited supply of V5 (Duo and Single) available on Gadget Infinity every Monday, Wednesday, and Friday 00:00 PST.
Please accept our sincere apologies if this supply shortage has caused any inconvenience for you. Lastly, we'd like to thank you for your support of Cactus Image and Gadget Infinity, and we look forward to serving you soon.
Kind regards
Gadget Infinity
Re:weldra...
« Reactie #26 Gepost op: 24 januari 2011, 19:28:51 »
Re:weldra...
« Reactie #25 Gepost op: 20 januari 2011, 12:56:45 »
Bedankt voor de Link Andre.
Heb meteen een mod gevonden om de trigger te laten werken met de nieuwe pentax flitsers
http://www.pentaxforums.com/forums/933892-post6.html
Re:weldra...
« Reactie #24 Gepost op: 20 januari 2011, 11:59:10 »
Hier een uitgebreide user test/review op het grote Pentaxforum.
De V5 triggers zijn wel een flink stukje groter dan de V4.
http://www.pentaxforums.com/forums/pentax-camera-field-accessories/128986-cactus-v5-radio-flash-trigger-review.html
Gadget infinity heeft inmiddels ook een prijskaartje aan de V5 set gehangen ($35 voor enkele, $60 voor setje)
http://www.gadgetinfinity.com/blog/2011/01/1189/
Re:weldra...
« Reactie #23 Gepost op: 11 januari 2011, 22:41:27 »
hoe ver zou de p-ttl eigenlijk werken?
dit is natuurlijk (?) afhankelijk van de gebruikte flits ? intern/360/540
En met de Cactus-setjes werkt dat natuurlijk helemaal niet  8)
Dan moet alles handmatig...
Re:weldra...
« Reactie #22 Gepost op: 11 januari 2011, 20:31:06 »
ah, ik denk te klein :D
gr Jos
Inderdaad. En de gebruikte brandpuntsafstand speelt ook een rol.
Re:weldra...
« Reactie #21 Gepost op: 11 januari 2011, 20:09:01 »
gr Jos
Re:weldra...
« Reactie #20 Gepost op: 11 januari 2011, 17:36:59 »
Of voor m'n mezenfoto's.
Flitsers achter in de tuin, vlak bij de vetbollen. Ik lekker warm in de huiskamer  :D
Re:weldra...
« Reactie #19 Gepost op: 11 januari 2011, 09:01:04 »
zo'n groot bereik vindt ik nutteloos; waar ga je dat voor gebruiken?
Tijdens mijn zwembad shoot ....25 meter bad.
De start fotograferen vanaf de andere kant.
Offline Kirsten
Re:weldra...
« Reactie #18 Gepost op: 11 januari 2011, 00:24:19 »
Klopt, of tijdens een outdoor model fotoshoot. Ik zie mezelf dit niet doen enkel met camera en flits zonder trigger set.
Re:weldra...
« Reactie #17 Gepost op: 11 januari 2011, 00:17:56 »
gr Jos
Voor aan de andere kant van het voetbalveld. Zaterdag was er een fotograaf met duo flitsset werkend op accu op statief die op de ijshockeyvloer stond en hij bv 20 meter verder met korte telelens de sprong met flits op de foto.
Re:weldra...
« Reactie #16 Gepost op: 11 januari 2011, 00:07:56 »
portret werkt ook prima. het bereik kan je vergroten door niet de interne flitser te gebruiken maar een 360 0f 540 op de camera te zetten.
gr Jos
Offline Kirsten
Re:weldra...
« Reactie #15 Gepost op: 10 januari 2011, 23:22:47 »
houdt de sensor van de losse flitser gericht op de camera +  het werkt niet goed in de volle zon. zodra het wat donkerder/bewolkt is heb ik met een meter of 4-5 prima bereik.
grJos
Ja da's héél mooi en kan leuk zijn voor macro of close-up fotografie maar daar eindigt het bij.
met de Cactus V4, heb ik reeds zelf getest, zo'n 75 meter bereik tussen camera en off-camera flash.  ;)
Re:weldra...
« Reactie #14 Gepost op: 10 januari 2011, 22:46:56 »
Dat is leuk om horen!  :)
ik had hetzelfde vreugde gevoel toen ik pas mijn flits had aangekocht en draadloos verbonden had met
m'n K10D, en ik wil jou niet ontgoochelen, maar merkte al gauw dat je beide toestellen niet verder dan één meter van
mekaar kan verwijderen. Wanneer je verder afstand neemt is het helaas schluss met draadloos flitsen tussen camera en flits.
en nou weet je meteen de reden waarom ik een trigger setje heb aangekocht...  :good:
grJos
Re:weldra...
« Reactie #13 Gepost op: 10 januari 2011, 22:30:33 »
mmmm en kan die samen met de ontvangers van de V4 werken?
Nee maar je kan natuurlijk de V4 zender op de V5 zender zetten  ;)
edit: m teveel  :schaam:
« Laatst bewerkt op: 10 januari 2011, 22:49:48 door Anvh »
Re:weldra...
« Reactie #12 Gepost op: 10 januari 2011, 21:54:04 »
Re:weldra...
« Reactie #11 Gepost op: 10 januari 2011, 21:48:38 »
Als je de sensor (zit volgens mijn in de body van de flits) naar de camera richt gaat het een stuk beter.
Offline Kirsten
Re:weldra...
« Reactie #10 Gepost op: 10 januari 2011, 21:46:56 »
Heb trouwens net de Metz 48-AF1 draadloos met de K-5 verbonden, dus ik kan weer even vooruit...  :-\
Gr. Don
Re:weldra...
« Reactie #9 Gepost op: 10 januari 2011, 21:31:00 »
ik snap alleen het nut niet van de verschillende groepen als je ze toch individueel moet instellen
Is er voor om te zorgen dat je buurman/vrouw met een cactus v5 jou flitsers niet laat af gaan, of bedoelde je dat niet?
Vind de mulit trigger wel handig, kan je de verschillende type verlichtingen controleren en aanpassen en dan allemaal op 1 groep gooien.
Nu alleen nog een optie waar je de groepen zelf aan en uit kan zetten, dus dat je een foto kan maken met en zonder rim-light bijvoorbeeld.
Misschien is dat voor V6.
Bedenk me nu opeens dat je de v5 kan stapelen maar denk niet dat dat zo handig is  :D
Offline PentaxDonkey
Re:weldra...
« Reactie #8 Gepost op: 10 januari 2011, 21:25:16 »
Leuk! Ik ben benieuwd wat de prijs gaat worden.
Mooi om ons op de hoogte te houden. Super!  :good:
Gr. Don
Re:weldra...
« Reactie #7 Gepost op: 10 januari 2011, 21:20:36 »
ok, iig ben je niet de enige met wat trubles.
Re:weldra...
« Reactie #6 Gepost op: 10 januari 2011, 21:01:28 »
Jos het was niet echt een sync probleem, andere filters deed die het wel gewoon goed.
Ik denk dat het misschien een van de extra contacten te maken kan hebben die Pentax gebruikt of dat de flitser hogere trigger voltage nodig heeft als die koud is, maar dat is allemaal gok werk van mijn kant.
