Volgens mij heeft de K10D nog geen mogelijkheid om de focus bij te stellen. Of ik heb er zwaar overheen gelezen
Enkele jaren geleden circuleerde dit bericht op diverse fora:
Hi,
I have big news!
If your K10D have problem with focus, you can adjust it yourself.
Someone in Korea figured it out himself.
He is not a employee of Pentax or related company.
He just found out by trial-and-error with key-set.
Of course, You yourself is responsible for doing something scribed below.
Here's How-to-adjust-focus.
1. Your K10D' firmware version must be 1.10.
2. Test shot for focus trouble.
3. Turn the camera OFF.
While pressing [PLAY]+[OK], Turn the camera ON.
You can see firmware version on LCD screen.
4. Firmware version is appeared,
then press [Fn]->[Fn]->[INFO]->[MENU] within 5 seconds.
You get service menu!!!
5. by pressing [right key]
,Make DEBUG MODE to DEBUG MODE .
then press [OK].
(save and LCD will be black out)
6. Press [MENU] and go to SETUP tab.
then, Press [Up key], you can see TEST MODE.
7. Select AF TEST menu. now you have AF correction menu.
If you have Front-focusing, reduce the value.
If you have back-focusing, increase the value.
after adjust some value, press [OK] and quit out of setup menu.
8. TEST for focus, find out that focus is correct.
(repeat this from 6 for correct focus.)
9. Go to service menu(step 3,4).
then press [OK].(save and LCD black out)
10. Go out and enjoy nice photos!!!
AGAIN, You yourself is responsible for any damage or trouble by doing this process!!!!!!!!!!!!!
