Versie 5.0 is uit van dit fijne HDR-proggie.
Update Log
20-Nov-13 - Updated in v5.0
Main new features in v5.0
- New Tone Mapping method named Contrast Optimizer. It is good at producing realistic-looking results while still enhancing shadows and highlights. You can access it via the 'Balanced' preset (second on the list).
- New Fusion method called Fusion/Real-Estate. It is intended for rendering interior scenes with a view out of the window. It replaces the Fusion/Realistic method available in batch mode in version 4.2.
- Option to enable Exposure Fusion when a single RAW file is loaded.
- Automatic Deghosting offers additional options: You can adjust the Deghosting strength and select the base exposure used, with the help of a preview of the deghosted image.
- Updates in Batch of Bracketed Photos: You can now select a Preset directly from the main batch window, and can also process with multiple presets and custom settings.
- More options on Workflow Shortcuts panel. In particular, ability to return with one click to the last session to process the image again with different settings.
- Option to refresh Preview continuously as slider moves. You can enable it on the General section of the Preferences dialog (not available when the OS is Windows 32-bit).
Other updates in v5.0
- Significant improvements to alignment of hand-held images.
- Automatic highlight recovery is now used before tone mapping a single RAW file.
- When using Photomatix Pro via the Lightroom Plugin, photos part of a Collection are now re-imported into the Collection.
- Better support for multiple monitor configurations.
- Contextual help for Merge to HDR Options shows in a help frame.
- Bug fixed: Minimising and restoring Photomatix main window could result in displayed images not being shown correctly.
- Bug fixed: Open and Save As dialogs always appeared on the primary monitor, even if Photomatix was displaying on a different one.
- Bug fixed: Setting information embedded in output images was incorrect when using Batch Bracketed Photos.
- Bug fixed: Some windows opened in incorrect locations if Photomatix was closed when minimised.
- Bug fixed: Photomatix did not show in the task bar on startup if the Workflow Shortcuts window was disabled in the preferences.
- Bug fixed: Minimising and then restoring Photomatix main window made Finishing Touch window disappear.
- Bug fixed: Values for red and blue were swapped around in the Preview for adjusting the White Balance when loading RAW files.
